VectorToRasterPopulator_ClippingFactoryPipeline
  • Jul 17, 2020 2:15 PM UTC
  • 0 replies
  • 26 views
oliver.morris
Forum|alt.badge.img+14
We are having issues with performance using the DEM Distance Calculator. The issue probably lies in the fact FME is trying to be too precise. Working with a large polygon and a 5km raster cell
In the logs we see:
VectorToRasterPopulator_ClippingFactoryPipeline::CLIPPER (ClippingFactory): Clipping with an automatic tolerance of 1.6032000000000016e-11
Is there a way to change this tolerance and make things run faster.
Also I attach the workbench to try to see if there are other barriers to the performance.
Many Thanks
Oliver
