VariableSetter and VariableRetriever bug? - FME 2020.1.0.0 Build 20510
  • May 8, 2020 3:17 PM UTC
  • 97 views
When using a SQLCreator or Creator, I can't get the VariableRetriever to attach attributes to the created data. It works correctly with any other data but not the creator(s).
Can anyone else replicate this behavior?
FME 2020.1.0.0 (20200305 - Build 20510 - WIN64)
Works correctly with a shapefile input
_value is left null for the creator and SQLCreator records
Best answer by david_r
It's probably an issue with the order of the features. Try setting a breakpoint on the incoming connection for all the Variable* transformers, execute the workspace and check where the execution stops first. If it isn't on the VariableSetter, that could explain the issue.
Try also setting "Create at end" = Yes on the Creator.
  • May 8, 2020 3:23 PM UTC
Adding a sorter for any attribute corrected both of the issues.
Thank you kindly!
