Using the XMLTemplator to dynamically populate an XML tag using a list values.
  • Dec 2, 2020 11:54 AM UTC
  • 7 replies
  • 101 views
andrewj74
Forum|alt.badge.img+8
I am new to lists and xml in FME and having a bit of trouble. I am using the XMLTemplator to populate an XML tag using a list value. The following works as it should.
for $Contact_id in fme:get-list-attribute("Contact{}")
return <NRWContact>{$Contact_id}</NRWContact>
However I am also using a different list which has been produced using the list builder and the name of the list is appended on the end so can get it to recognise it to get the value.
for $ExcelColumnName_id in  {fme:get-list-attribute("list{}.ExcelColumnName")}
return
<Location>$ExcelColumnName_id</Location>
This just returns  “<Location>$ExcelColumnName_id</Location>” and not the value from the list  e.g <Location>Column B</Location>”. Hopefully it’s a simple tweak but I have not stumbled across it yet or found the same thing on the community.
Best answer by ebygomm
I think you can do something like this, but I'm sure there are some other XML experts about who might be able to offer better advice, @Takashi Iijima​
let $values := fme:get-list-attribute('list{}.NewValue')
let $names := fme:get-list-attribute('list{}.XMLFieldName')
for $v in $values
let $n := $names[index-of($values,$v)]
return
{    element {$n} {$v}}
Any better?
for $v at $index in $values
let $n := $names[$index]
return
The issue with the one posted earlier was that you obviously have values that are the same for different elements and that causes a problem as it's trying to use the value as a lookup. This avoids that
Forum|alt.badge.img+54
  • Dec 2, 2020 12:12 PM UTC
It looks like you have some curly brackets in the wrong place, try
for $ExcelColumnName_id in  fme:get-list-attribute("list{}.ExcelColumnName")
return
<Location>{$ExcelColumnName_id}</Location>
andrewj74
  • Dec 2, 2020 3:15 PM UTC
Thank you that did the job. i dont supose you colud help me further. Basically i am trying to dynamically template and XML document from a list.
list Example
list{0}.NewValue (encoded: UTF-8) 1
list{0}.XMLFieldName (encoded: UTF-16LE) Key
list{1}.NewValue (encoded: UTF-8) Yes
list{1}.XMLFieldName (encoded: UTF-16LE) Licenced
list{2}.NewValue (encoded: UTF-8) No
list{2}.XMLFieldName (encoded: UTF-16LE) External
list{3}.NewValue (encoded: UTF-8) Tim
list{3}.XMLFieldName (encoded: UTF-16LE) Name
desired output
<Key>1</Key><Licenced>Yes</Licenced><External>No</External><Name>Tim</Name>
i have been trying this in the xmltemplater but it fails with the following error (sequence of more than one item can not be cast to QName). I think it is failing as it cant handle the element being defined by a list value.
element
{fme:get-attribute("Licencing Dataset URI")}
for $NewValue_id in  fme:get-list-attribute("list{}.NewValue")
return
{$NewValue_id}
The other way i was thinking of tackling it is by the following whick also fails:
for $XMLFieldName_id in  fme:get-list-attribute("list{}.XMLFieldName")
return
<{$XMLFieldName_id}>{$NewValue_id}</{$XMLFieldName_id}>
Sorry i am new to xquery but any pointer would be much appreciated.
  • Dec 2, 2020 4:34 PM UTC
list Example
desired output
element
return
{$NewValue_id}
return
for $v in $values
return
andrewj74
  • Dec 3, 2020 9:33 AM UTC
for $v in $values
return
thank you @ebygomm​ , think its getting there :)
this fails as
invalid argument type for function fn:boolean(): effective boolean value not defined for sequence of more than one item that starts with "xs:integer"
i have tried a few variations of the above be get similar errors. @Takashi Iijima​  are you able to advise?
Many thanks
andrewj74
  • Dec 3, 2020 10:05 AM UTC
for $v in $values
return
i actually have a sequence in my list that can be used  which is the order that the xml elements are required in. i see the index of function starts at 1 so there would be a mismatch there..
list{0}.NewValue (encoded: UTF-8) DH1111
list{0}.sequenced (64 bit real) 0
list{0}.XMLFieldName (encoded: UTF-16LE) BusinessKey
list{1}.NewValue (encoded: UTF-8) 2222
list{1}.sequenced (64 bit real) 1
list{1}.XMLFieldName (encoded: UTF-16LE) LicenceID
list{2}.NewValue (encoded: UTF-8) n/a
list{2}.sequenced (64 bit real) 2
list{2}.XMLFieldName (encoded: UTF-16LE) SLicenceID
  • Dec 3, 2020 11:33 AM UTC
for $v in $values
return
Any better?
return
andrewj74
  • Dec 4, 2020 10:25 AM UTC
for $v in $values
return
Thank you so much for your help - this worked a treat
