Using <Auto> in a scripted parameter
  • Aug 9, 2022 2:29 PM UTC
  • 46 views
pflegpet
Forum|alt.badge.img+8
Im trying to write a scripted parameter to allow only specified EPSG codes from the CsmapReprojector and apply the correct transformation . Based on a chosen source and destination CRS selected by the user a certain transformation is applied. This works fine, except when I try to use the <Auto> parameter. According to the documentation I should "Use the alternative blank string and NULL_FME respectively when passing in as an attribute." Unfortunately when I use "" as blank string in my script, the workspace fails because "Parameter 'TRANSFORMATION' must be given a value."
So how do I pass a "blank string" that triggers the automatic transformation in CsmapReprojector? My script looks something like this:
import fme
if fme.macroValues['SOURCE_CRS'] == 'EPSG:25833' and fme.macroValues['DEST_CRS'] == 'EPSG:31468':
  return 'DHDN_to_ETRS89/01_local_grid_FME (Reversed)'
else:
  return ""
Thank you for your help!
pflegpet
  • Aug 9, 2022 2:58 PM UTC
I found the solution - I had to uncheck the "Required" checkbox in the parameter options. Now I can pass an empty string in the script to trigger the automatic transformation.
