Using AreaOnAreaOverlay. are there any parameter to provide higher or lower value resulting attribute(accumlation mode) where the polygon overlap?
  • Sep 30, 2016 11:29 PM UTC
  • 51 views
Using AreaOnAreaOverlay. are there any parameter to provide higher or lower value resulting attribute(accumlation mode) where the polygon overlap? I only see only options: drop, merge, 1st. Need help and guidance.
Best answer by takashi
Hi @shihg, I don't think the AreaOnAreaOverlayer has an option to do that, but if you check the "Generate List" checkbox and specify a list name in the AreaOnAreaOverlayer parameters, the ListRangeExtractor might help you to retrieve the min and max of attribute values stored in a list component.
  • Oct 1, 2016 1:21 AM UTC
  • Oct 3, 2016 11:55 PM UTC
Appreciated your quick response. I am uncertain what the next steps should be after the generated list so the MAX value correlates toward the overlapping polygon. Thank you in advance for your help.
  • Oct 4, 2016 12:14 AM UTC
For example, if you set "AOA_list{}.MPH" to the "Source List Attribute" parameter in the ListRangeExtractor, the transformer retrieves the min and max of MPH for each overlap area.
