Upgrade: If we're only upgrading from 2021.2.0.1 (21789) to 2021.2.1.0 (21797), do I still have to have my DBA wipe out the tables and create new?
  • Dec 21, 2021 8:35 PM UTC
  • 58 views
jhawks
Forum|alt.badge.img+7
Hi @jhawks​ ,
Yes, whenever you are upgrading FME Server you must create a new database using the scripts provided by that specific version. The reason for this is that the database schema can change between versions so a mismatch will cause problems with FME Server functioning.
