Updating MS Access table using fme_db_operation
  • May 5, 2015
  • 5 replies
  • 81 views
I am trying to update a field in an access table using fme_db_operation UPDATE. My workspace seems to work when viewing the results in Inspector but is failing to update the actual table. Not sure what I am missing.
Any help will be greatly appreciated.
Thank you.
  • May 6, 2015
What kind of error message has been logged when the translation failed?
Takashi
gio
Forum|alt.badge.img+15
  • May 6, 2015
Format/index/constraint violation maybe?
  • May 6, 2015
Hi Takashi and Gio,
The translation does not fail. Its just that the access table is not getting updated. I have set writer mode to UPDATE. Is there anything else I need to look at?
Thanks
Samir
  • May 7, 2015
In the "Format Parameters" tab of the writer feature type properties dialog, check if the "SQL Key Columns" parameter has been set properly.
  • May 7, 2015
Hi Takashi,
Yes I had put wrong attribute field for "SQL Key Column". It is working now. Thank you for your help.
Samir
