Update an Oracle table from an Oracle table VIEW...is it possible and how to set it up, please?
  • Jul 30, 2021 5:04 PM UTC
  • 61 views
I have an FME process that updates one Oracle table from another via a ChanageDetector process. I notified the DBA that the table I am reading from is missing a field. The DBA created a able VIEW with the missing field and advised I use that to update the other table.  I don't see Oracle table VIEWS as an option in the Reader I am using. Can an Oracle table VIEW be used in a Reader? If so, how is that accomplished?
Thanks in advance.
geomancer
Forum|alt.badge.img+71
  • Aug 2, 2021 6:54 AM UTC
Are you reading a spatial view? Then the metadata of the view needs to be defined in MDSYS.SDO_GEOM_METADATA. See here for more info.
