Unexpected Output with the FeatureMerger
  • December 28, 2016
  • 8 replies
  • 110 views
Hi World of FME,
I am a newbie with FME but I already worked a lot with the FeatureMerger. But at the moment I have a problem with an output I cannot really explain. In the screenshot you see the attribute tables, that enter the FeatureMerger as Requestor und Supplier. Also you see the transformer output I expect and below you see the real output: No feature could be merged and I have no idea what the problem is.
Thank you for answers or hints,
Felix
  • December 28, 2016
Hi @felixderglueckl, I believe that the FeatureMerger works as expected. Set 'id' to the 'Join On' for Requestor, set 'end_id' to the 'Join On' for Supplier and NOT set 'Group By', like this screenshot.
Hi @takashi, thank you for your answer.
I did it exactly like that and unfortunately it does not work :(
  • December 28, 2016
Strange. Check if your workspace has any difference from this simplified demo workspace (FME 2016.1.3): demo.fmwt
nielsgerrits
Forum|alt.badge.img+67
What version FME @felixderglueckl
itay
Forum|alt.badge.img+19
  • December 28, 2016
is it possible that the attribute values on which then join is done are not the same ? Spaces in the values can cause this kind of behviour.
  • December 28, 2016
You have set 'Yes' to the 'Suppliers First' parameter, but I don't think the option can be applied in this workflow. Probably it's the reason for the unexpected result.
Actually that was my fault @takashi Thank you very much. It did work! :)
  • January 3, 2017
Also try setting the comparison mode to "String", I've experienced some unexpected behavior in older versions of FME when the attributes to merge on looked like very long numbers.
