Unexpected Input.
  • Sep 18, 2017 2:48 PM UTC
  • 318 views
maica
Forum|alt.badge.img+4
Hello,
I implemented a workflow that read a shp file, does some basic elaboration and writes the result in an Oracle table.
I call the input file using a variable.
Now, if I modify the input (more record but with the same structure), I receive this message in a window in FME Desktop:
"Unexpected Input: During translation, some feature were read that did not match a reader feature type in the workspace. This can happen if the reader dataset if changed, or a reader feature type removed or renamed."
If I execute the same workflow in FME Server, I don't receive any error message, but zero feature are written in oracle.
Any idea about this strange behaviour? What can I do to better investigate?
Thanks.
Best answer by fmelizard
Hi @maica, check out this blog article that discusses the message you're seeing. Don't worry, it's not an error :)
fmelizard
Forum|alt.badge.img+22
  • Sep 18, 2017 3:39 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Sep 19, 2017 2:26 AM UTC
@TiaAtSafe this blog article is powerful and interesting.
maica
  • Sep 19, 2017 5:02 AM UTC
Thank you so much
