Understanding the JSONUpdater
  • Jul 12, 2024 12:35 PM UTC
  • 423 views
brad
Hello there,
I feel like this should be incredible simple, but I feel like I am banging my head against a wall.
I am trying to update the name value in this JSON, ‘cp2regions’ to ‘new_name’ for example:
  "featureType": {
    "name": "cp2regions",
    "nativeName": "cp2regions"}
 Using this this workbench;
Set up like this :
I can’t seem to find a good tutorial/example workbench on how this Transform works.
Many Thanks!
liamfez
Forum|alt.badge.img+44
  • Jul 12, 2024 2:11 PM UTC
Looks like you are missing a connection there for the information to perform the update. You also can remove the last part of the JSON Path which is referenced in the Object/Array Index section.
Attached is a sample workspace where I took your input json txt and updated it using a feature with an attribute for the new name.
Here is some documentation: JSONUpdater (safe.com)
