Unable to convert OGCGEOPACKAGE wkb_multi_polygon to compatible FME geome
  • Dec 15, 2023 9:30 AM UTC
  • 160 views
jugoslaviaa
While reading a gpkg file, I am getting the following error, Does anyone know what i can get over this error?
grafik
nielsgerrits
Forum|alt.badge.img+67
From the log:
Encountered a wkb_polygon with zero rings.
Hard to say without data, but I think it found a geometry defined as a polygon without a closed polyline.
A GeoPackage is essentially a sqlite db, so to debug this you can try to read it using FME as sqlite, or use another tool to read sqlite and see what is in the geometry column and go from there.
geomancer
Forum|alt.badge.img+71
  • Dec 15, 2023 12:41 PM UTC
For reading GeoPackage (and SQLite) files, I'm a big fan of DBBrowser.
