Unable to connect to AGOL using FME Desktop 2016
  • June 15, 2016
  • 74 views
gisgeek
Forum|alt.badge.img+9
I am currently going around in circles but I am unable to connect to AGOL. I get the following error:
ArcGIS Online Feature Service Reader: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='www.arcgis.com', port=443): Max retries exceeded with url: /sharing/generateToken?f=json (Caused by ProxyError('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Access Denied',)))'
Has anyone else come across this and found a solution.
darkspatiallord
Forum|alt.badge.img+8
As the error said, have you checked your filewall and proxy settings.
Make sure if you have a proxy you have set it under Tools > FME Options > Network.
