UAV imagery to blend into Aerial Imagery
  • October 6, 2017
  • 80 views
Hi all,
I am having issues with blending captured UAV orthomosaic (.jpg) into aerial imagery (.jpg as well). I used a few approaches including creating boundary polygon to use as a clipper as well as setting alpha band to exclude black edges to mosaic with aerial imagery. As a result I get merged images with white edges instead.
I looked at couple of solutions that floating around knowledge center but did not get it working. If anyone can suggest a solution that would be great.
Cheers,
Maksym
daveatsafe
Forum|alt.badge.img+24
  • October 10, 2017
Hi @mkhovalko,
The workspace looks good, but we may need to check some of the transformer parameters. Please check the following:
- Both RasterInterpretationCoercers are coercing to RGBA32
- The RasterMosaicker Has Overlapping Values set to Composite using Alpha Band
  • October 10, 2017
Hi @DaveAtSafe, thanks for your reply.
You are correct, the only setting that I had to change was RasterMosaicker to Overlapping Values set to Composite using Alpha Band.
I had to geo reference Aerial imagery to fit UAV ground control points and the results looks good:
