TwitterSearcher search parameters
  • Feb 27, 2017 3:28 PM UTC
  • 7 replies
  • 73 views
Hello, I am using TwitterSearcher and I was wondering if I could search a string with more than one words, e.g. "Big Car" instead of just "Car". Or even multiple words? Thanks
Best answer by david_r
According to the Twitter search API documentation, searcing for
big car
will return both "big" and "car". If you search for
"big car"
it'll return only the exact phrase.
More info here under Query operators:
https://dev.twitter.com/rest/public/search
Just be aware of the following limitation:
Before getting involved, it’s important to know that the Search API is focused on relevance and not completeness. This means that some Tweets and users may be missing from search results. If you want to match for completeness you should consider using a Streaming API instead.
  • Feb 27, 2017 4:43 PM UTC
big car
"big car"
  • Feb 28, 2017 11:45 AM UTC
Thanks david_r!
  • Apr 3, 2017 10:21 AM UTC
It seems that TweetSearcher is looking for the Keywords as one string, eg if I search for the phrase: "big car"@mplampa, it is searching for the string "big car @mplampa", instead of the phrase "big car" mentioning twitter account "mplampla".
Therefore, I cannot see how I can use the query operators as shown in Twitter Search API webpage (https://dev.twitter.com/rest/public/search).
What I want to do is look for words or phrases in specific twitter accounts.
Can anyone shed some light please? Thanks.
  • Apr 3, 2017 12:04 PM UTC
You may want to contact Safe support for this one, having the source code for the TweetSearcher transformer will be necessary to say how they've implemented the API in the transformer.
  • Apr 3, 2017 12:18 PM UTC
Thanks for the reply David_R. I have done so. I will let ypu know their answer once I get it.
  • Apr 6, 2017 11:57 AM UTC
I found out that you can use the operators as shown in the Twitter API without a problem! It seems that FME is doing the URL encoding automatically. Thanks.
  • Apr 6, 2017 12:02 PM UTC
That's excellent news, thanks for sharing.
