Trying to update/delete from an SDE (non versioned) featureclass, But only part of the data is written ?
  • May 20, 2022 6:39 AM UTC
  • 68 views
I'm trying to update/delete from an SDE featureclass using fme_db_operation, The changes are grouped in 4 groups: 2 delete and 2 updates. The Deletes work fine, the first update group (updates both geometry and attributes) works fine.
But the the last update group (updates only attributes) does not write data to DB. There is no errors, there is 5 exspected warnings (non existing keys) but for the rest of the +70.000 records there is no indication of anything is wrong - except the data is not updated.
Best regards
hkingsbury
Forum|alt.badge.img+73
  • May 22, 2022 8:59 PM UTC
Can you share the workbench and the related log file?
