Trim remove more than required
  • Mar 13, 2024 12:15 PM UTC
  • 5 replies
  • 134 views
nurbek
Forum|alt.badge.img+3
Hi There,
i have workspace and trim transformer - Post/processe/Radarsat2/20240313 for example, it should leave 20240313 name of the file, but it remove 2 at the begining, 0240313 remains as file name. How to keep that “2” at the beginning?
Best answer by nielsgerrits
There’s also an transformer LastSectionOfStringRemover on Hub that might help you here:
https://hub.safe.com/publishers/safe-lab/transformers/lastsectionofstringremover
(split on / and keep last part)
Also the FilenamePartExtractor should work in this case.
nielsgerrits
Forum|alt.badge.img+67
When I do this I use an AttributeSplitter and a ListIndexer.
becchr
Forum|alt.badge.img+35
  • Mar 13, 2024 1:40 PM UTC
nielsgerrits
  • Mar 13, 2024 2:24 PM UTC
geomancer
Forum|alt.badge.img+71
  • Mar 13, 2024 2:35 PM UTC
Or use a StringSearcher with regular expression \d*$
This will find all digits from the end of the string (or you can use \d{8}$ for exactly the last 8 digits).
nurbek
  • Mar 19, 2024 4:12 AM UTC
Did not know about this transformer, was useful in my case
