Translation was SUCCESSFUL despite of ERROR in Logfile??
  • February 22, 2016
  • 111 views
vki
Forum|alt.badge.img+8
We have to run various workbenches (and other scripts) automatically and repeatedly with different timeperiods in between, so I wrote some python scripts to run them.
In those scripts I check the returncode of FME and if it's <> 0 (Translation was successful) then my scripts throw an error.
But obviously FME sometimes returns 0 (Translation was successful), even though there is an ERROR in the Logfile and the translation was NOT successful.
How come? Isn't this a bug?
Thanks in advance
Vera
2016-02-22 04:40:44| 221.4| 0.0|INFORM|XLSX Reader: Opening dataset '\\\\ktsz003\\groups$\\AVG\\Geoinformation\\Produkte\\GDI\\Themen\\A018 AV\\data\\a018_Domain_EOB.xlsx'...
2016-02-22 04:40:44| 221.4| 0.0|ERROR |XLSX Reader: Failed to open the dataset '\\\\ktsz003\\groups$\\AVG\\Geoinformation\\Produkte\\GDI\\Themen\\A018 AV\\data\\a018_Domain_EOB.xlsx'. Error message was 'can't open file for reading'
2016-02-22 04:40:44| 221.4| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2016-02-22 04:40:44| 221.4| 0.0|INFORM|XLSX Reader: Closing dataset '\\\\ktsz003\\groups$\\AVG\\Geoinformation\\Produkte\\GDI\\Themen\\A018 AV\\data\\a018_Domain_EOB.xlsx'...
2016-02-22 04:40:44| 221.4| 0.0|ERROR |Error occured while reading feature from table `Joiner_5:Domain' : `A fatal error has occurred. Check the logfile above for details'
2016-02-22 04:40:49| 221.6| 0.2|ERROR |... Last line repeated 459 times ...
2016-02-22 04:53:23| 269.2| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2016-02-22 04:53:23| 269.2| 0.0|STATS | Features Written Summary
2016-02-22 04:53:23| 269.2| 0.0|STATS |==============================================================================
2016-02-22 04:53:23| 269.2| 0.0|STATS |Total Features Written 0
2016-02-22 04:53:23| 269.2| 0.0|INFORM|Translation was SUCCESSFUL with 2 warning(s) (0 feature(s) output)
2
Best answer by mark2atsafe
Yes, I do find that sometimes we don't stop a translation when we should or that we stop when we shouldn't. Can I suggest you file a case with our support team (safe.com/support) or your local reseller support.
Either we should change this to a WARNing, or - if it stays as an ERROR - we should halt the translation. But we'll probably need a copy of your workspace and source data to be able to replicate the problem
Oh! I'll also mention that there is a parameter in the Navigator window (Workspace Parameters > Advanced > Ignore Failed Readers) that could legitimately cause an error to be ignored. So first check that is not set to Yes before filing a case.
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
mark2atsafe
Forum|alt.badge.img+59
  • February 22, 2016
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
  • February 22, 2016
This is a security issue... Error message was 'can't open file for reading'
FME doesn't have an access to read your File. You can ignore your Failed Reader but it's not a good option in batch process.
vki
  • February 23, 2016
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
The parameter "ignore failed reader" ist set to No. (The error lies in a Joiner-Transformer that tries to open an Excel-File that doesn't exist)
I'll send the the workbench to the support.
