Translation log promt for yes/ no
  • May 22, 2020 7:48 AM UTC
  • 42 views
kidega
Forum|alt.badge.img+9
Hello,
I am using SystemCaller to delete temporary files during translation. Now I store them in a created folder "Temp" that I'd like the SystemCaller to delete with all its contents.
The typed text in SystemCaller is:
Del $(Output)\\Temp
where the $(Output) is a public parameter.
At the end of the translation it prompts to delete the full directory with
*, Are you sure (Y/N)?
Is there a way to type the Yes choice in the SystemCaller? Otherwise translation will get stucked here.
For single files the Del command works fine in SystemCaller.
Thanks.
  • May 22, 2020 7:53 AM UTC
Try using the /q option to suppress the delete confirmation question, see the 'del' documentation: https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/del
kidega
  • May 22, 2020 8:12 AM UTC
Thanks @david_r !
Your suggestion was an easy fix.
