Translation Log not giving the correct information
  • Feb 1, 2021 1:26 AM UTC
  • 57 views
brandonguo
Forum|alt.badge.img+7
I am using fme_db_operation to write some data into SQL spatial server.
After the running finished, in translation log it says:
Features not written - verify feature type fanout/dynamic settings
(Check that fanout/dynamic feature type attribute exists and has a value)
12809
Total features not written 12809
From my checking, all new data are insert successfully.
Another error log is:
Microsoft SQL Server Spatial Writer: Data type `identity' of attribute `gisids' of feature type `featureXXX' is not supported for writing. Attribute will be ignored by writer.
The attribute was not ignored, it successfully updated in the database. I am really get confused by the log, it can't give the correct workbench running result.
@brandonguo​ You probably need to have your FME Reseller take a closer look at this. I'd suggest you file a support case with them. They'll probably need to see your workspace and data - perhaps through a screen share
