Translating colors into values,
  • March 13, 2014
  • 85 views
jamal
Forum|alt.badge.img+5
I have already highlighted this issue on other threads but I want to further elaborate it in a separate one.
In my work, each landuse is indicated by a hatch of particular color (in the AutoCAD). This color refers to a particular meaning as shown in the screenshot below.
As hatches are converted to polygons using the FME, I need to translate the color of each hatch into its meaning in Arabic and English and to store these values in two columns as shown in the screenshot below
Is SchemaMapper the best way to do so?
Thank you
Best
Jamal
Best answer by takashi
# correction for a typo.
Joiner
  • March 13, 2014
I do not think the SchemaMapper is good choice in this case.
AttributeValueMapper
You can import the value mapping table in the parameters dialog. But the setting is static, so it's not suitable when the mapping rule should be determined at run-time.
If the mapping rule is dynamic, I think that joining tables (usind color  value as key) is suitable way. Major choices are:
FeatureMerger (read the table with the Excel reader beforehand)
Jointer
InlineQuerier
  • March 13, 2014
Joiner
gio
Forum|alt.badge.img+15
  • March 14, 2014
..i was wondering..did i miss the Jointer?
sounds like a cool transformer.
Legal in Colorado, yes?
Gio
jamal
  • March 15, 2014
Thank you Takashi.
The “joiner” works fine
Best
Jamal
