translate empty features
Good morning. I have a quick questio. I need to migrate the schema from a geodatabase to an empty CAD file. I just want to make sure I have the same schema in the CAD file and to be able to leverage domain vaules etc. Is this possible using FME?
Thanks
  • April 27, 2014
I don't really have a specific answer to your question, but in general it is my experience that FME isn't too strong at handling the repliction of empty schemas.
Since FME is feature-driven (Feature manipulation engine!) it has a tendency to skip all operations where there are no features entering.
If you don't get an answer here, consider contacting your reseller or Safe support.
David
  • April 28, 2014
Hi David,
 I was able to translate the empty schema  from GDB to a CAD file using the creator transformer.  Basically I had to modify the input  type on the creator to assign a geometry type different than the destination. In other words if my destination was a polygon, I assigned a point or a line geometry in the creator. No idea why it works like that but thats what the documentation said to do. The problem was that I lost all of my GIS Schema when that happened.
