Transformer that splits line by measure?
  • Jun 25, 2020 5:03 AM UTC
  • 192 views
nicholas
Forum|alt.badge.img+14
I am using NetworkCostCalculator to calculate driven distance along a network, storing the cost as a Z-value (though I could switch to Measure)
Is there a way of splitting the line at a specific value (3500 metres) of the Measure?
And then keeping those streets below the same value (3500 metres)?
I am currently using a Contour Generator, but that gives bad results when a road loops around and comes back with the tail end getting caught inside the contour even though the driven distance is too long
Best answer by ebygomm
The snipper will allow you to cut at measure values
Forum|alt.badge.img+54
  • Jun 25, 2020 8:14 AM UTC
nicholas
  • Jun 25, 2020 10:55 PM UTC
Do you mean Snipping Mode: Distance (Value)?
And what do I enter for Starting Location and Ending Location?
Starting Location: 0 and Ending Location: 3500 does not work. That keeps the entire line
nicholas
  • Jun 26, 2020 2:37 AM UTC
Hi @ebygomm I have implemented the Snipper and it works. I also looked at an answer by @takashi to a similar question posted last year, which gave me the correct settings for the Snipper. I would create a link back to that post here, but I don't know how
