Transformation FORMULA in defining custom datum
Hi all, I'm defining a custom datum in MyCoordSysDefs.fme, using Bursa transformation method (which is described as an approximation of the Seven Parameter Method). But I confuse because there are 2 formulas of this method, named "Position Vector" (as defined by EPSG:9606) and "Coordinate Frame" (EPSG:9607). What is exactly the formula of Bursa/Wolf transformation using in FME ?
Best answer by fmelizard
I think you will have a better chance of an answer by directing this question to safe.
Hope this helps,
Itay
