Transfer a row from translation log to attribute table
  • May 13, 2022 2:01 PM UTC
  • 88 views
quangu
Hi!
In the translation log, i have tried to add a specific row (in my case row 85) to attribute table without any result. Is this possible to do it? The pythoncaller script (Esri Arcgis Python 3.7) look like this:
import fme
import fmeobjects
from arcgis.gis import GIS
from arcgis.apps.storymap.story import StoryMap
from arcgis.apps.storymap.story_content import Image, TextStyles, Video, Audio, Embed, Map, Text, Button, Gallery, Swipe, Sidecar, Timeline
from arcgis.gis import Item
from arcgis.apps.storymap import Themes
class FeatureProcessor(object):
  def __init__(self):
    pass
  def input(self, feature):
    gis = GIS("home")
    new_story = StoryMap("9f1567e92c514baabdc2e595776bfdc8")
    new_story
    new_story.nodes
    newFeature = fmeobjects.FMEFeature()
    self.pyoutput(newFeature)
    print(new_story.nodes)
  def close(self):
    pass
  def process_group(self):
    pass
arcgis package 2.0.0 in ArcGIS Pro needed to run this script. A similar script without arcgis package 2.0.0 work fine,
Thank you for your assistance!
Forum|alt.badge.img+54
  • May 13, 2022 2:20 PM UTC
If you want to have the output as text in an attribute rather than the log file you will need to set the attribute before outputting the feature
It looks like the output (new_story.nodes) is a dictionary, so you will also need to convert before you'll be able to set as an attribute. You can do this by importing the json module and then doing something like
newFeature.setAttribute("nodeid",json.dumps(new_story.nodes))
quangu
  • May 16, 2022 6:19 PM UTC
I modified it to newFeature.setAttribute("nodeid",str(new_story.nodes)), and it worked perfectly. Thank you!
