Touching solids
  • February 28, 2017
  • 51 views
j_geo
Hello,
I have some well organised solids that touch each other.
Is it possible to get information about which solid is touching which?
I import solids from SketchUp (they are imported as aggregates) and make
them with SolidBuilder.
Another question: If it is not possible to find touching solids, is it possible to find
faces that are overlapping?
daveatsafe
Forum|alt.badge.img+24
  • February 28, 2017
Hi @jernejtekavec,
The Clipper transformer will clip a solid by another solid, returning the intersection volume. You can use this to find overlapping solids.
j_geo
  • March 1, 2017
Hi Dave,
thanks for answer. I tried Clipper and I seem to be doing something wrong.
I connect my solids to clipper and clipee inputs. I have 17 touching solids.
I get 17 rejected (invalid geometry type) and 17 from "inside" output.
Both outputs contain original solids.
