topology builder
  • November 11, 2013
  • 48 views
I have a Mapinfo Tab file of Points that have an Attribute called 'Code'.
Data contained in this field is in the format of ABC# SL or ABC# EL.
What I need to do is create a line between Nodes whos attributes match e.g. ABC1 SL and ABC1 EL.
SL stands for Start Line and the EL stands for End Line.
Thanks
Shane
Best answer by takashi
Hi Shane,
I would use the StringSearcher, Sorter and PointConnector with the following parameter settings.
StringSearcher: Split the Code into 2 parts.
Attribute: Code
Regular Expression: ^(.+)(SL|EL)$
Matched Parts Attribute: _parts
_parts{0} contains "ABC# ", _parts{1} contains "SL" or "EL".
Sorter: Sort the points by the Code (front part) and SL -> EL order.
Attribute  |  Alpha/Num  |  Order
_parts{0}  |  Alphabetic  |  Ascending
_parts{1}  |  Alphabetic  |  Descending
Point Connector: Connect points grouped by the Code (front part).
Connection Break Attributes: _parts{0}
Hope this helps. Takashi
  • November 11, 2013
Hi Shane,
Attribute: Code
