Topology builder
  • Jun 8, 2017 7:41 AM UTC
  • 126 views
nath
Forum|alt.badge.img+7
Hi
Here i am again :-)
I use the topology builder (lines and nodes) to connect my network correctly but is there a way to exlude the builder to make new nodes on lines who intersects?
The builder makes al lot of new nodes (because the point aren't snapped good enough (even after using the snapper and anchored snapper). So sometimes its aloud to have a node on a intersection, if there's an existing node.
I use the tester and a neighborfinder to search the Original nodes and to replace the bad snapped ones but the lines are also split in two and i don't want that :-)
Hope somebody can help me!
Grtjs
Nathalie
  • Jun 8, 2017 7:44 AM UTC
Hi @nath, try setting Yes to the Assume Clean Data (Advanced) parameter in the TopologyBuilder.
  • Jun 8, 2017 7:48 AM UTC
Regarding the Snapper/AnchoredSnapper: have you tried using the "Segment snapping" mode?
nath
  • Jun 8, 2017 7:50 AM UTC
Ashamed that i didn't think of that, Thx!
I have overlooked that option
nath
  • Jun 8, 2017 7:51 AM UTC
Thx i will try that!
