Tool to disperse points around an identical position ?
  • February 15, 2017
  • 5 replies
  • 324 views
lifalin2016
Forum|alt.badge.img+41
I'm continiously acquiring tasks for internal FME execution that previously was done by a mix of command lines and t-sql. One of the tasks involved was dispersing points with identical coordinates to unique positions in the vicinity. This task is currently kept in a stored procedure.
I would like to also transfer this functionality to FME proper.
Before I venture into recoding the stored procedure into a custom transformer, I'd like to hear, if anyone has encountered a similar problem, and has found a good solution ?
Cheers.
Best answer by redgeographics
There's a SpreadDuplicatePoints transformer in the FME Hub, sounds like it does exactly what you want.
itay
Forum|alt.badge.img+19
  • February 15, 2017
Hi, I have seen some amazing things been done with the offset, maybe you should have a look at it...
erik_jan
Forum|alt.badge.img+26
  • February 15, 2017
Have a look at this Question and answer:
https://knowledge.safe.com/questions/25031/offset-points-on-a-circle.html
It might give you an idea how to solve your question.
Forum|alt.badge.img+63
  • VIP
  • February 15, 2017
itay
  • February 16, 2017
Hi @lifalin2016,
Have a look at this workspace: offset.fmw,
The number of copies defines the number of circles around the original point. Should range from 1 till 3 but can be adjusted along with the mapping in the valuemapper.
  • February 16, 2017
Hi @lifalin2016,
Hi @itay, thanks for sharing the Cloner+Offsetter example. As advanced/new Offsetter usages, can you add workflows using the Polar Coordinate mode and Spherical Coordinate mode? :-)
