Tolerance for transformers such as LineOnLineOverlayer in FME 2016
  • Jun 14, 2022 3:33 PM UTC
  • 50 views
arthy
Forum|alt.badge.img+8
In recent version of FME, it is possible to define a tolerance value when using transformers such as LineOnLineOverlayer.
We are having an old FME server (2016) and I would like to know how can I proceed to define a tolerance value when overlaying two lines datasets in FME 2016?
@Takashi Iijima​ @Mark Stoakes​ @jdh​ and others
Forum|alt.badge.img+63
FME 2016 didn't have this option, you can sort of emulate it though by snapping the lines to eachother first, using a Snapper or AnchoredSnapper. Both have a tolerance option, though not the "automatic" tolerance setting that later versions have.
On a side note, as support for FME 2016 stopped 2 years ago this may be a good time to consider upgrading.
