To merge points from a line (with color) into one line
  • Sep 26, 2021 2:54 PM UTC
  • 73 views
giuseppecfgeo
Forum|alt.badge.img+5
Hey community!
How can I merge des points from a line into one line?
I have a lot of "points lines" that I create with the transformer "Iterative Snipper" to chop that every meter in the lines. And now I want to merge every points in lines with color from points (attached picture).
Tnkx a lot!
danilo_fme
Forum|alt.badge.img+58
  • Sep 26, 2021 7:18 PM UTC
Hi @giuseppecfgeo​
Please, take a look the transformer LineBuilder.
https://www.safe.com/transformers/line-builder/
Thanks in Advance,
Danilo
hkingsbury
Forum|alt.badge.img+73
  • Sep 26, 2021 7:19 PM UTC
You can use the LineBuilder, but this does assume that the points enter the transformer in the correct order.
eg, if the start and end point enter first, followed by the remaining middle points then your result isn't going to be great
