Tiler issues
  • Mar 7, 2018 9:13 AM UTC
  • 7 replies
  • 98 views
I want to tile Buffered line feature and after that want to dissolve it. But the tiler tile only the total boundary. And do not provide any features into the tiled box. Need some suggestion.
  • Mar 7, 2018 9:23 AM UTC
When I encounter unexpected behavior in FME, the first thing I try is to insert some Inspectors after each transformer to see what's going on. That might give some clues.
gio
Forum|alt.badge.img+15
  • Mar 7, 2018 9:58 AM UTC
@yasinmelon1
Hi.
Hard to see how that workspace outputs the features you post.
The only way I can come up with is you have such a dense roadnetwork that when buffered by the amount you use, yields the same area as the original boundary.
You are indeed to inspect your input at least.
This is the result after Bufferer transformer. I cannot understand why the features looks so heterogeneous.
  • Mar 7, 2018 10:05 AM UTC
I would say that, based on the screenshot above, the result looks like expected.
Can you perhaps explain what you'd like the result to be?
  • Mar 7, 2018 10:52 AM UTC
If you combine the density of your road network with the size of the buffers, it seems you're ending up with buffers covering the entire territory, as per your screenshot. When dissolving all those buffers, you get a polygon covering the same surface as the buffers.
This is basically what @gio says as well.
Consider trying a smaller buffer size or perhaps also filtering away minor roads.
mark2atsafe
Forum|alt.badge.img+59
Maybe a dumb question, but what coordinate system is the data? If it's Lat/Long then you need to give it a decimal degrees buffer size. Or reproject into the same units as your buffer. Sorry, that's probably not the issue... but I have seen it happen before.
  • Mar 7, 2018 3:03 PM UTC
Or use the GeographicBufferer...
