TestFilter not working as expected
  • Feb 10, 2014 9:24 PM UTC
  • 86 views
jon
Forum|alt.badge.img+5
Using a TestFilter, I want to find matching IDs from two different sources.  The first source is a custom format with a field called ObjectID and the second source is from a FGDB feature class with a field called GlobalID (38 characters instead of 36 for some reason):
When I look at the format of each, FME says the following: ObjectID [string(38)]
GlobalID [char(38)]
I thought my TestFilter wasn't working since the data types are different.  I added a StringFormatter to change both to a string (Format String: s) and thought this would do the trick.  I didn't or I don't know how to properly configure this.  I also tried removing the curly brackets but that didn't work either.
I copied the values out from the inspector, and from what I can tell, they are identical and SHOULD pass through the "Attribute Match" port. GlobalID = {1A34BEC4-FE38-4D9C-B280-75CEB5D8B6CB}
ObjectID = {1A34BEC4-FE38-4D9C-B280-75CEB5D8B6CB}
What am I missing??
Best answer by gazza
A TestFilter isn't the right transformer here, it only works on one feature at a time so you would only get a match if a feature had both GlobalID and ObjectID attributes that were identical.
Try using a FeatureMerger instead and match on GlobalID and ObjectID and look for matched data out the Merged port.
gazza
  • Feb 10, 2014 10:00 PM UTC
jon
  • Feb 11, 2014 2:16 PM UTC
Gazza - FeatureMerger did the trick.  Thanks for your guidance!
By the way, I just looked at the help for TestFilter/Tester (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/testfilter.htm) and didn't notice anything about it only working on one feature at a time.  How are you supposed to know that if it's not in the help?
