tester for blank values
  • Dec 3, 2014 12:10 AM UTC
  • 181 views
hi
im trying to set up a tester to pick up any blank streetname column .
ive tried 1. where string value is empty
               2. value is "" (see attched screen shot)
but its not working . please avice
  • Dec 3, 2014 12:54 AM UTC
I believe that the first method (leave "Right Value" blank) works well.
Check if the street name is really empty (see the value using the Logger).
Just be aware that a string consisting of whitespace(s) is not an empty string.
In addition, the "Attribute is Empty String" operator can also be used to test whether an attribute value is empty. "=" operator + blank right operand does not distinguish "empty", "null", and "missing". The "Attribute is Empty String" returns true only when the left operand is "empty".
Takashi
  • Dec 3, 2014 2:41 AM UTC
Thanks Takashi
kept the right value blank and it worked !
simple things .....
thanks for your help
gio
Forum|alt.badge.img+15
  • Dec 4, 2014 1:52 PM UTC
handy way is also to use [
 LEFTVALUE:  = [REGEXP {.+} {@ATTRIBUTE}] RIGHTVALUE: 0
{.+} is a string with something i it
{.+} can also be used in stringsearcher &Co.
