TCPIPReceiver Query
  • Apr 19, 2017 1:12 PM UTC
  • 80 views
Hi, I'm trying to query a TCP/IP protocol service. Not having much exposure to the TCP/IP protocol I'm wondering if it is the workflow of the TCPIPReceiver? I can confirm the workbench is hitting the target server with the query created in the Attribute Creator however I'm getting no response from the server. See attached image of workbench.
Any advice would be appreciated?
Image of workbench
itay
Forum|alt.badge.img+19
  • Apr 24, 2017 9:02 AM UTC
Hi @robertlewis,
I am not sure how you are setting up the TCPIPSender initiation sequence setting, but looks like it should be set to Establish and therefore running before the TCPIPReceiver.
I am not sure if this is possible to set the order in one workspace so I would try placing the TCPIPReceiver and the rest of the lower second half of the workspace in a separate workspace.
Hope this helps.
  • Apr 29, 2017 6:26 AM UTC
Hi @robertlewis, I think you will have to run the TCPIPSender and the TCPIPReceiver in different processes (i.e. different workspaces) separately. For example, while the first workapace is running to send a data stream with a TCPIPSender (Initiation Sequence: Establish), you can run the second workspace to receive the stream with a TCPIPReceiver (Initiation Sequence: Connect).
  • Apr 30, 2017 10:25 PM UTC
Thank you both @itay and @takashi for the feedback , I'll try this workflow later on this week.
