Take action based on feature count
  • Mar 1, 2022 11:25 PM UTC
  • 139 views
mattwilkie
Forum|alt.badge.img+11
I'm sure this is really basic but I'm stumped. How do I take some sort of action based on the number of features emitted by a previous transformer?
In this particular instance I need to abort the final write (and send an email) if the number of features are less than 2000. I have a Counter, and can see the number of features. I have a Tester, but it appears to be testing each feature instead of the total count.
Counter and Testertester equation: _count > 2000
Best answer by mattwilkie
In my scenario Aggregator turned out to be the better transformer to use. When I used FeatureCounter an email was sent for every single record in the incoming stream!
andreaatsafe
Forum|alt.badge.img+17
Hi @mattw1ilkie​ ,
There are a few ways I can think of to do this: a FeatureCounter or a StatisticsCalculator (select an attribute and just get the total count).
Then you can use a Tester to test the attribute that is created that will hold the total number of features coming through.
(Then a Terminator transformer for the Failed port of the Tester - if you are looking to end the workspace if anything comes out of the Failed port)
Hope this helps!
Andrea
mattwilkie
  • Mar 2, 2022 10:08 PM UTC
