SystemCaller and FME Server Linux edition
  • November 28, 2016
  • 65 views
Cheers!
I'm working on a FME routine containing quite a few SystemCaller transformers containing psql calls to remote DB servers. This worked fine on Win and then suddenly I decided to try out FME for Linux ;0
Thing is that I'm left clueless of how to use the SystemCaller to pass my command to a Linux shell.
Trying the following from SystemCaller:
"sudo -u postgres /opt/fmeserver/resources/temp/truncate_temp_db.sh"
And the .sh is just your plain simple psql command to a remote server:
"psql -h <host> -p <port> -U <user> -d <database> -c "<SOME SQL HERE>;"
Permissions to execute .sh is set to all users hoping that "fmeserver" user have the neccesary privileges, but I still haven't had any luck with this approach. I'm not that Linux savvy I have to admit so if someone can give me a nudge in the right direction - I'd really appreciate that. I can revert to using SQL executor for this but I really want to know if SystemCaller is any good on FME for Linux.
Kind regards,
Saamot
mark2atsafe
Forum|alt.badge.img+59
I don't see why it wouldn't work. Do you get an error message anywhere that might help to debug this. When you say you have no luck, what happens? I would also turn on log debug under the FME Options to give a little more information in the log about what action is being carried out.
fmelizard
Forum|alt.badge.img+22
Can you run those exact commands from the command line when logged in as the user under whom the FME Server runs? I can imagine lots of ways that doing "sudo" without the right permissions/paths could go off the rails.
ravenkopelman
SystemCaller is fully supported on Linux.  Assuming that the postgres user requires a password for sudo, you'll need something like
echo <password> | sudo -S -u postgres /opt/fmeserver/resources/temp/truncate_temp_db.sh
in order to avoid hanging FME while a password is waited for.  If that is not the problem, please post a description (or log snippet) of how your workspace is failing.
  • December 2, 2016
Exactly the solution I was looking for. Thanks!  :)
