Surface Modeller getting stuck
  • Aug 9, 2019 4:04 PM UTC
  • 180 views
soothsayers
Forum|alt.badge.img+7
I am using a Surface Modeller during the creation of TINs for 3D output. The majority of the time this works absolutely fine but some processes seem to stall at the same point (starting to build surface model) and I can't seem to work out why.
It succeeds when there are more input coordinates than shown in the final line above. It succeeds with some more complex topographies than those that fail. It fails when there is only 1 Group in the output.
I have tried altering the Surface Tolerance to a larger number but this made no difference, except to make the successful output more generalised!
It occasionally stalls when building the Voronoi Diagram too, although we use the Triangles output in the process as opposed to Voronoi.
It fails in both Desktop and Cloud environments.
Thanks in advance!
Best answer by daveatsafe
Hi @soothsayers,
This seems like a good case for our support team (https://www.safe.com/support/report-a-problem/), who will reproduce this problem, and create a problem report for our development team.
daveatsafe
Forum|alt.badge.img+24
  • Aug 9, 2019 4:26 PM UTC
Hi @soothsayers,
khangi
Participant
  • Participant
  • Dec 23, 2020 9:10 AM UTC
I had the same problem this week using a SurfaceDraper transformer.
In my case, the solution was to first use an Orientor transformer to change the orientation type to Right hand rule orientation.
we have been doing some fine tuning to the SurfaceModeller (and related transformers like SurfaceDraper and VoronoiDiagramer) in FME 2021 and hopefully this will have addressed some of these issues where SurfaceModeller hangs.
