Suppress certain warnings
  • Sep 22, 2022 12:18 PM UTC
  • 202 views
fme_hans
Is it possible to supress certain warnings in the translation log?
For example, when i use a Oracle spatial reader with 2 or more geometry columns I use the parameter "Spatial Column : GEOMETRY1". In the translation log I get: Column `GEOMETRY1' of table `A_TEST' has been chosen to hold the geometry.
I would like to remove such warnings in from the log.
Forum|alt.badge.img+63
You can specify to not log information, warnings or errors, but other than that there's no control over it. Not down to specific transformers/readers/writers
