sum up the populations for an areia from household count from points
  • Feb 23, 2022 6:52 AM UTC
  • 7 replies
  • 63 views
Hi
I have two datasets, one water distribution area in polygons, and a point layer with the count of people inside each household per adress.
i want to count up the sum of people in total for an each area.
The count of people is in the point layer. i have tried the pointoverareaoverlayer but i only get the count of points inside an area, not the count from people inside the area
Forum|alt.badge.img+54
  • Feb 23, 2022 8:13 AM UTC
If you build a list containing the population attribute in the PointOnAreaOverlayer (tick Generate List On Output 'Area'), you can then use a ListSummer to sum all those values
geomancer
Forum|alt.badge.img+71
  • Feb 23, 2022 8:22 AM UTC
Sum_Occupants
  • Feb 23, 2022 9:20 AM UTC
Sum_Occupants
Thanks for the answer i still struggle to make it run propperly.
do i have to cross of for group by mode?
geomancer
  • Feb 23, 2022 11:22 AM UTC
There is no attribute on the Points features you might use to group by.
So in this case there is no need for Group Processing.
@elarse4​ If it's a bigger dataset, then creating the list might get a bit unmanageable. In this case use the PointOnAreaOverlayer as @geomancer​ suggests, but don't generate the list. Just transfer the polygon ID to each point. Then use the StatisticsCalculator on the points, with Group By : Polygon ID to sum up your population count
  • Feb 24, 2022 5:54 AM UTC
Hi figured it out i enden up using spatial relation so the polygon ID got transfered to the points and then i used the statistics calculator as mentioned in the post under.
after that i used a feature manager so write the groups to the polygons again so i could export it to a shape file.
thanks for the answers
this is what i ended up doing.
