String formatting getting lost in transformation
  • Jan 23, 2018 5:30 PM UTC
  • 8 replies
  • 75 views
sashal
Forum|alt.badge.img+13
My strings lose their formatting once they hit my feature merger. Any help would be greatly appreciated.
sashal
  • Jan 23, 2018 5:31 PM UTC
@daleatsafe
any ideas?
Hi @sashalockamy,
May we ask for a bit more information please? What kind of formatting is lost in the string? Do you have a sample workspace or data you can share with us? Screenshots would also help, if you would prefer not to share data.
It would also be great if you could share some details about the build of FME you are using as there have been some updates to the FeatureMerger since 2016.1.
Any assistance or information you are able to provide that helps narrow down the issue would be fantastic.
Cheers,
Annabelle
  • Jan 23, 2018 5:54 PM UTC
Please add some context to help everyone understand the problem to help you!
Give examples please.
sashal
  • Jan 23, 2018 8:00 PM UTC
Sure. Below, at attributeManager_2 to inspection, my strings look great, but once they go through the FeatureMerger_3, the output reformats my strings...
sashal
  • Jan 23, 2018 8:09 PM UTC
here is the workspace...sp1-import-custom2.fmw
here is the desired output at shown in inspection results desired-output-inspection.png
here is the actual output which is no good because it reformatted my string to 2240 vs 0224 in the usaa_acct field actual-output-no-good.png
sashal
  • Jan 23, 2018 8:38 PM UTC
@mark_1spatial I added info on my issue... will you please take a look?
sashal
  • Jan 23, 2018 9:08 PM UTC
I was able to create a secondary workspace to merge two outputs and get the results I needed. Still not sure why the feature merger was changing my string length...
  • Jan 24, 2018 1:04 AM UTC
Do you perhaps look at the resulting CSV table with Excel? Excel displays this CSV table like the screenshot below.
value
0019
019
19
0019-2240
019-2240
19-2240
You have to inspect the CSV table with a Text Editor or FME Data Inspector to confirm whether the string format has been lost actually.Left: Text Editor (Notepad++), Right: Table View in FME Data Inspector
