Strange behavior of a job when launched by WorkspaceRunner
  • Nov 20, 2023 3:55 PM UTC
  • 110 views
lgrie
Forum|alt.badge.img+8
Hello,
I have a (tough) nut to crack.
A TestFilter of a job, run by a WorkspaceRunner, receives data but does not copy them into his output.
TestFilter_12_INPUT (TeeFactory): Cloned 2589 input feature(s) into 2589 output feature(s)
TestFilter_12 (TestFactory): Tested 2589 input feature(s) -- 51 feature(s) passed and 2538 feature(s) failed
TestFilter_12 LR valid Transformer Output Nuker (TeeFactory): Cloned 45 input feature(s) into 0 output feature(s)
TestFilter_12 BT valid Transformer Output Nuker (TeeFactory): Cloned 6 input feature(s) into 0 output feature(s)
The very same job, when run manually it gives this information :
TestFilter_12 (TestFactory): Tested 2589 input feature(s) -- 51 feature(s) passed.
I don't understand why the behavior changes according to the way of launching it.
Someone has an idea ?
itsmatt
Forum|alt.badge.img+48
  • Nov 20, 2023 7:08 PM UTC
I have actually had a similar experience very recently. I had set up a logger to verify the features were going where I expected but nothing was being logged.
I saw very similar things as you see in your log about the TestFilter.
I put it down to the fact that nothing was being processed (only logged) so FME decided it didn't need to output those features - as if an output connector wasn't connected.
What do you have after your test filter?
lgrie
  • Nov 21, 2023 7:33 AM UTC
A GeometryFilter.
itsmatt
  • Nov 21, 2023 7:39 AM UTC
A GeometryFilter.
And after that? Do you have any writers or anything in the workspace connected to those outputs?
Which version of FME? - I noticed this only in FME 2023
