Stop PointOnAreaOverlayer after checking all points
  • Jan 8, 2021 8:14 AM UTC
  • 67 views
I would like to check if some points (around 2,000) overlap with building areas (around 54 million). When running the PonitOnAreaOverlayer it takes about 1.5 h to run as the transformer needs to count all the polygons, too. Is there a possibility to stop the transformer running after the points went through? I am still a beginner to FME, so there is probably only one single click to do...
Best,
Jo
Try using a FeatureReader with a 'Spatial Filter'of intersect.
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/featurereader.htm
Example process process times for a dummy project I just made with a large shapefile;
Feature Reader
170,000 rows intersecting 1 point = 100 results
2.2 seconds
Adding as a shapefile reader with PointOnAreaOverlay
40.7 seconds
@jojojoe​  FeatureReader is probably the answer, as @jlbaker2779​ suggests. But only if your building areas have a spatial index. So if your source is a file based dataset, make sure it has an index file. If it's a database, make sure the index is up-to-date.
  • Jan 11, 2021 9:25 AM UTC
Thanks to @jlbaker2779​ , works fine and it takes around 13 minutes, only. I've added the spatial index to the points shapefile, the building areas had one before.
Excellent! Big improvement!
