SQL to run after Write (dynamic writer) using fme_feature_type as dynamic (table name).
  • May 27, 2022 12:11 PM UTC
  • 266 views
so_much_more
After the dynamic writer is done i need to update some column for each feature type being written.
Something along the lines with (its not the actual SQL, this one is simplified for demonstration )
update public.$(feature_type_name) -- This is table name
set area = ST_area(geom)
I want that to be run as
update public.park
But fme_feature_type is not available. Can i do this without hardcoding the feature types names?
panda
Forum|alt.badge.img+20
  • May 27, 2022 2:11 PM UTC
In Feature Writer > Output Ports I think you can choose Specified: (@Value(fme_feature_type) and that would allow the fme_feature_type to come out the port after dynamic writer. I hope I understand your questions correctly!
fme_feature_type
so_much_more
  • May 30, 2022 7:22 AM UTC
Yes good point, that could work. One thing I would like to do is do create/update spatial index after writing to the database. Using a duplicate filter afterward to run a single transaction on the feature type (instead of one transaction per feature).
