Sql Executor and Workspace runner
  • May 25, 2013
  • 28 views
I got a translation going on with few sql executors and a workspacerunner .A sql executor is placed after Workspace runner as well.Now a strange thing is observed when I set the "wait for job to complete" as yes the oracle procedures are called from executors and are reflected in the table.
But when set to no ,none of the procedures seem to work though the log shows them being called .
Is this a bug ?
Best answer by takashi
Hi Roy,
When setting 'No' to the parameter, the SQL sentence(s) of the following SQLExecutor could be executed before comleting job of the workspace called by the WorkspaceRunner. So, if the table is the target which should be created or updated in the called worksapce, the SQLExcecutor will fail or generate unpreferable result. I guess this is such a situation.
Takashi
  • May 26, 2013
Hi Roy,
Takashi
