Splitting out rasters for RasterExpressionEvaluator
  • October 14, 2013
  • 85 views
jaslee
Participant
I have 2 grayscale rasters which I want to combine using the "RasterExpressionEvaluator", BUT they differ slighty in the number of rows and columns which is why my workflow fails.
I want to run this script several times so I want to dynamically work out the rows and columns of both rasters which we can get these values with the "RasterPropertiesExtractor". I then work out the MIN of both rows and cols using the "ExpressionEvaluator" and resample both rasters to this common dimension using the "RasterResampler".
Because I need to number of rows and columns of BOTH rasters, the workflow from both raster inputs are COMBINED, but now I want to use the "RasterExpressionEvaluator" in "Two Rasters" mode, how can I separate out the 2 rasters again to that I can assign them into the appropriate "A" and "B" input ports??
Hope my quetsion is understandable!(!)
fmelizard
Forum|alt.badge.img+22
  • October 14, 2013
I would look into the fme_basename value, that is in case the rasters have different names (which is usually the case).
Hope this helps,
Itay
jaslee
Participant
  • Participant
  • October 14, 2013
I know I could use the fme_basename to separate them out but how exactly? I hear about "Fanout" but that is only avaiable on the output writer which is an endpoint right?
I my case, I want to fanout BUT I want to continue the workflow with the "RasterExpressionEvaluator" as mentioned.
Jason
jaslee
Participant
  • Participant
  • October 14, 2013
I think I know now - I can use the TestFilter on the fme_basename to search on a common term - in my case it would be "*slopeshade*" and "*hillshade*". I will give this a try, thanks!
Jason
fmelizard
  • October 14, 2013
Hi Jason,
Yes that was my initial idea, but actually you can use the group by setting on the raster expression evaluator (set to fme_basename) to calculate per raster (pay attention to the mode setting aswell).
Hope this helps,
Itay
