splitting blm sections into rough quads
  • Jun 25, 2013 2:42 AM UTC
  • 57 views
ls-vea
Hello,
I'm a FME novice at best. Could anyone help me split many irregular polygons into 4 equal parts? I have a section grid for a small area within a state and I need to split each section into quads. I don’t need the split to be exact, just 4 polygons with the same attributes at the parent section.
Thanks
Best answer by takashi
I think it's not so easy to divide an irregular polygon into just 4 polygons. I cannot  immediately find a solution.
But, if what you need to do is something like tiling, the Tiler transformer can be used.   Takashi
  • Jun 25, 2013 7:32 AM UTC
