Split up polygon where it becomes long and narrow
  • Jan 13, 2020 3:52 PM UTC
  • 11 replies
  • 251 views
I have a dataset where polygon sometimes have a long and narrow part like in this image (upper narrow part of the highlighted polygon):
I am looking for a way to cut polygons like this in two parts so that the small polygons becomes a separate shape.
Any idea how to do this automatically?
danilo_fme
Forum|alt.badge.img+58
  • Jan 13, 2020 5:31 PM UTC
Hi @oiram
Could you share us you example?
Thanks,
Danilo
erik_jan
Forum|alt.badge.img+26
  • Jan 13, 2020 9:58 PM UTC
Not sure it will give you a solution, but you could try the GeometryValidator transformer, check the "Self intersecion in 2D" and set Repair to Yes.
You will need to set a Tolerance to make these Self Intersecting.
Hope this helps.
  • Jan 14, 2020 6:48 AM UTC
Yes, here is a example:
narrow_poly.json
danilo_fme
  • Jan 14, 2020 1:25 PM UTC
narrow_poly.json
Thanks your source.
In words do you want to cut this polygon ( example ) in two parts:
Correct?
Thanks,
Danilo
  • Jan 14, 2020 1:35 PM UTC
Thanks your source.
Correct?
Thanks,
Danilo
Yes, exactly.
danilo_fme
  • Jan 14, 2020 2:41 PM UTC
Hello @oiram
I create a Workspace that identify the long and narrow Polygons ( CircularityCalculator and Tester ) and after to separate polygons:
result
Attached the Workspace - Workspace_Long.fmw
Thanks,
Danilo
  • Jan 14, 2020 3:05 PM UTC
Hello @oiram
result
Thanks,
Danilo
thanks a lot :-)
danilo_fme
  • Jan 14, 2020 3:50 PM UTC
thanks a lot :-)
You are wellcome
  • Jul 24, 2022 11:00 PM UTC
Hi Danilo,
Would it be possible to share the Workspace_Long?
Thanks,
Vladislav
LizAtSafe
Forum|alt.badge.img+27
  • Jul 26, 2022 2:53 PM UTC
Hi Danilo,
Thanks,
Vladislav
Hi @vlad_mdc​ I fixed the original file attachment and have also attached it to this comment for your reference.
  • Jul 26, 2022 9:06 PM UTC
Hi @lizatsafe​
Thanks a lot!
