SpatialRelator cardinality question
  • October 21, 2014
  • 87 views
gio
Forum|alt.badge.img+15
Hi all,
I noticed that using cardinality in the spatialrelator does not output _relationships{}.card_area.
It is always 0.
I even tested it with the simplest possible of tests: 2 squares partialy overlapping eachother with a intersect or a overlap test or whatevertest..._relationships{0}.card_area is still 0???
I know form a earlier post, when i was still using fme2013 (i'm only using fme2014 for a cple of months now)  that it was broken. But is it still broken? That would suck indeed.
That would be disconcerting...seeing as a lot of scripts of mine use this function.
Best answer by gio
In case anyone wants to know..
This transformer is still bugged.
Safe answered the problem is not solved yet.
(in 2013 it is working ok btw.)
gio
  • October 23, 2014
