HI Stefen,
SpatialRelator: When I put the line.shp into the Base port and the polygon.shp into the Candidate port. In the transformer properties I set 'Tests to perform to TOUCHES'. Result is all the line.shp?? Allowed Geometries for line is "Shape_polyline" and for Polygon is "shape_polygon"?
And if the Result is one spot where the line intersects the polygon I can put outpout point.shp?? But Output is a line...
I'm new user without formation on FME...
